LabWindows/CVI
How to activate activeX componets in Lab Windows?
I try to add Omron CX Lite Active X to Labwindows but not succeeded yet.
There is a Communication control component which Properties is same as if I open it in the Excel and I am able to select project file as it should be.
If I add some data components Properties window is same as in the Excel but now there should be possibility to select Communication component/ PLC name and symbol name from the list but these combolist are empty.
From Lab windows Edit I can set these values but still lit is not working.
I have also tried to use these activeX  components from my Main program, but there are no error messages but still not getting any values from PLC.
Any hints what I can do to make it work?
Best Regards
Tapio Tammi
tapio.tammi@eu.omron.com
+358400412750
(4,867 Views)
Hi Tapio,
here are some information about Activex and LabWindows/CVI.
What ActiveX Features Does LabWindows/CVI Support?
http://digital.ni.com/public.nsf/allkb/F601F484A452EDBC8625754C004ED135
Hope there is some usefull information.
Jorghos
(4,669 Views)
