LabWindows/CVI
Font Resizing - TSUI.h
I'm trying to change the font size when a caption has been updated inside a label box.
The properties image allows me to change the font size to 39.75 as shown; however, it seems that when I do a post to the caption, the size gets set to a default value.
I checked to make sure that the font source is still set to 0 (FontSource_UseFontProperty).
Now, interestingly enough, I'm able to set the fore color of the caption, but any other attributes doesn't work. For example: TSUI_LABELSETENABLE.
Does anyone ever have the same situation? I've looked through the forumn and online and it doesn't seem to have information.
Side note: It seems that NI doesn't support Vertical Align properties yet either 😞
(3,741 Views)
To avoid having a long initial post, I did the following:
tsErrChk( TSUI_LabelSetCaption (gSocketWindow.statusLabel[(int)currentPanel], NULL, statusMessage.StatusMsg));
tsErrChk( TSUI_LabelSetBackColor (gSocketWindow.statusLabel[(int)currentPanel], NULL, 0xFF));
tsErrChk( TSUI_LabelSetForeColor (gSocketWindow.statusLabel[(int)currentPanel], NULL, 0x00F));
tsErrChk( TSUI_LabelSetFontSource (gSocketWindow.statusLabel[(int)currentPanel], NULL, 0));
The first 3 steps would work, but the 4th one doesn't.
(3,734 Views)
Hey B1ack1otus,
I think you are using TestStand UI Controls. Instead of posting it here, try posting it at on the TestStand Forum instead.
Ren H.
Applications Engineering
(3,685 Views)
Oh ok, thank you
(3,680 Views)
Accepted by topic author pinguu
error was caused due to the different ViewManager ...
Issue is resolved.
Only edited, Application View Manager, not the Execution View Manager.
(3,529 Views)
