LabWindows/CVI
Formatting pathname and filename correctly to call external app.
I'm trying to launch an external application that takes in a filename as a parameter.
I'm using FileSelectPopup to let the user select a file.
This returns a filename in the form of: "C:\proj\compose\images\blank.bmp" with single backslash.
Then I try to use LaunchExecutable or system() to launch an application that takes the selected file as a parameter; except that these two function need the path\file in the form of:
"C:\\proj\\compose.exe C:\\proj\\compose\\images\\blank.bmp" with double backslash.
How do I format my variable after FileSelectPopup correctly?
Thanks.
(3,129 Views)
Since the slash is already in a variable and not in a string constant, I don't think you need to double-slash it.
See my note and sample code here (reply 5 of 7).
The compiler tries to interpret a backslash in a string constant as a backslash code rather than a backslash character. But the backslash in a string is the backslash character.
(3,123 Views)
Thanks Al S. Yeah, I'm sure I have to double slash. I have to use the single slash for the picture control and double slash for the LaunchExecutable call... couldn't find a way around it.
Anyway, I used your suggestion, it's working. Thank you.
(3,103 Views)
