LabWindows/CVI
Formatting source file
when I ask CVI to generate a callback code from Control, I get the following result:
int CVICALLBACK MyProcedure (int panel, int control, int event,
                                        void *callbackData, int eventData1, int eventData2)
while I'd like to have the code written in this other way:
int CVICALLBACK MyProcedure (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
In order to get what I need, I have recorded a Macro, but of course I have to modify all the autogenerated code.
Is there any faster and automatic way to obtain what I want?
Sergio
(4,999 Views)
Hi Sergio, I'm not sure I've understood correctly. You simply would like code to be generated on one unique line? Bye, Licia
(4,968 Views)
Hi Licia, yes you've well understood, I'd like to have CVI generating Control callbacks as well as Panel callbacks on a unique line.
But more, I'd like to know if there is menu, where I can program CVI in order to have it generating Control callbacks and Panel callbacks in different formats as I need situation by situation.
Bye
Sergio
(4,964 Views)
