LabWindows/CVI
hipar
/// HIPAR (parameter)/text descripton not displaying on tooltip
///HIRET and HIFN Display ok
Message 1 of 8
(7,406 Views)
Hello John,
You need to provide more details.
  • What CVI version do you use
  • What's the function prototype?
  • How documentation  tags look like?
Constantin
Message 2 of 8
(7,402 Views)
using: cvi2103 sp1
note the empty description field in the html output there is also no detail on the tooltip for parameters.
I have also tried the ///OUT but with no success.
code:
/// HIFN    Ini_Read_File
/// HIFN NOTE: Loads configuration data from the .ini file
/// HIRET (integer) sucsessful read of configuration, negative value indicates failure
/// HIPAR *iniSection number of sections in the ini file which are read.
int Ini_Read_File(int *iniSection)
html output:
Ini_Read_File
int Ini_Read_File (int *iniSection);
Purpose
Ini_Read_File
Parameters
Input
Name Type Description
iniSection int *
Return Value
returnValue int (integer) sucsessful read of configuration, negative value indicates failure
References
Message 3 of 8
(7,372 Views)
Can you try with:
/// HIPAR iniSection/Number of sections in the ini file which are read.
/// OUT iniSection
and see how the output looks like? Note the slash betwee the parameter name and its description.
Message 4 of 8
(7,366 Views)
Hello John
The syntax for HIPAR is
/// HIPAR paramName/help text
 In you case it should be
/// HIPAR iniSection/number of sections in the ini file which are read.
 Hint: You can put the cursor inside the function and Edit>Insert Construct>Function Documentation Tags (Ctrl+Shift+G). This adds automatically the necessary tags.
Constantin
Message 5 of 8
(7,364 Views)
Thanks for responses:
Using
now displays on the html file in the debug folder
Note: do not use * when declaring pointer parameters and use forward slash with no spaces between parameter and description text
However the parameters still not apperaing on the tool tip. I have tried various combinations of /// HPAR and /// OUT
Message 6 of 8
(7,355 Views)
Hello John,
The parameter is shown in the tooltip when the cursor is on the parameter position(inside parentheses) and not on the function name.
Constantin
Message 7 of 8
(7,332 Views)
Many Thanks
So easy once explained, wish i had known how to use this feature earlier.
John
Message 8 of 8
(7,322 Views)
