LabWindows/CVI
Forward declaration of struct
Hi all,
I am trying to transfer an old program from CVI 2010 to 2017 and during the process , i encounter this problem.
The program has two .h files :
+ In the first h file , I have below struct:
struct Serie
  int product;
  unsigned int prod;
  char type[50];
  char setup[50];
  struct Date date;
  struct Time time;
  double humidity;
  double temperature;
  int coilsInSerie;
  int coilsMeasured;
  int coilsRejected;
  int coilsGood;
  int notInBandgroup;
  struct Parameter value[PARAM_NUM];
+In the second .h file , I include the first .h file and want to use Serie struct as an element of below struct:
struct Setup
int ableToMeasure[PARAM_NUM];
int switchPort;
struct Clamp clamp[2];
struct Serie serie[2];
  "SETUP.H"(45,21)error: array has incomplete element type 'struct Serie'
"SETUP.H"(45,10) note: forward declaration of 'struct Serie'
I now know I have to forward declare struct Serie , just i don't know how.
Somehow , the program complied fine in CVI 2010 , any help is appreciated though.
(3,858 Views)
Hi john_pe,
Can you post your whole code, or at least a simple reproducing case? This would be helpful for testing purposes to get to the bottom of this.
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(3,729 Views)
I also have this problem.
"array has incomplete element type" is done by the compilator on CVI 2017, and didn't on CVI 2009.
this code is in a file.h
extern struct S_KeyText g_message[];
Thanks for your help.
(2,541 Views)
That's C99 syntax.
Probably change it to:
extern struct S_KeyText *g_message;
(2,523 Views)
