LabWindows/CVI
debug64: non-debuggable thread caued a 'General Protection' fault
now it has hit me... running CVI2020 I can compile and run my function well in debug mode. However, when compiled and run in debug64 mode I get the fatal run-time error at unknown source position... (at address 1) when the function returns
I remember to have seen such an issue, but I am not sure and don't remember where...
My function looks like this
// block of code executing properly without issues //
} <- the error is thrown when the function returns; if I have a breakpoint before such as
; <- statement with breakpoint: all fine until here
Any help is much appreciated, thanks a lot in advance!
By the way, the resource tracking utility also does not show any issue
(2,462 Views)
hi
try to increase yout stack size on build option window or the default calling convention
(2,436 Views)
Thanks, I will give it a try and let you know 🙂
(2,417 Views)
I have increased the numbers maximum stack size and stack allocation size by a factor of 100 with no change in behavior.
However, when I deselect debugging (no run-time checks) everything works fine, so I conclude that this is an internal limitation of 32 bit CVI respective its debugger.
I will try to have NI look at it via filing a service request, but at the end of CVI's lifetime I am not so optimistic.
Thanks anyway for the suggestion!
(2,401 Views)
Accepted by topic author Wolfgang
I have been in contact with NI - and unfortunately, as I already expected, it turned out that the crash is another limitation of the LabWindows/CVI 32 bit application.
And because CVI uses its own memory manager it would be too much effort to fix this in a patch, according to NI - hence it will never happen 🙄
(2,309 Views)
