LabWindows/CVI
French message in CVI 6.0 application
Hi, i'm looking for a solution to make CVI 6.0 applications messages in
french System and popu messages and label. Could someone have solutions.
Thanks very mutch
(3,221 Views)
There is a file under your Windows system directory under \cvirte\msgrte.txt. This file has all of the CVI error and run-time engine messages in it. You can translate this file and put it in the same location and distributed executables will use the translated strings. Any messages from the system/OS, should use the language settings of the OS.
Best Regards,
Chris Matthews
(3,221 Views)
Than you very mutch,
it seem to work very well.
Do you know where i could find the french msgrte.txt.Just in oder to save
time.
Regards
"Chris Matthews" a écrit dans le message news:
5065000000050000005AAC0000-1031838699000@exchange.ni.com...
> settings of the OS.
> Best Regards,
> Chris Matthews
> National Instruments
(3,221 Views)
I would contact the French branch office of National Instruments as they would be the most likely to have a translated file already. The info for the French NI branch office is:
National Instruments France
Centre d'Affaires Paris-Nord
BP 217 - 93153 Le Blanc-Mesnil
tél : 01 48 14 24 24
fax : 01 48 14 24 14
Best Regards,
Chris Matthews
(3,221 Views)
For what I know the txt file you talk about is not yet translated. I guess it is mainly a long term maintenance issue.
Best regards, Philippe
Visit http://www.baucour.com
(3,221 Views)
