03-21-2017 11:31 AM
I'm seeing GPFs in RunUserInterface when inserting ring items in a column cells of a table control. It's repeatable now, although yesterday in development I'm pretty certain this was not happening. Lovely, I know.
I've stripped my project down to bare bones. Click the Add button to add rows. Click the Fail or Pass ring controls in any row and watch the GPF fireworks!
What am I missing here?
Solved! Go to Solution.
03-22-2017 04:01 AM
Hello Electro,
This seems indeed a but - CAR #637529 created.
The culprit is SetTableCellRingItemAttribute(embolden!) which breaks the internal state of the ring. Also setting other attributes with SetTableCellRingItemAttribute produce the failure.
The only workaround is to give up to embolden, sorry
Constantin=
03-22-2017
08:59 AM
- last edited on
08-21-2026
04:37 PM
by
Content Cleaner
After some more investigation I saw that SetTableCellRingItemAttribute is called with a wrong parameter.
// embolden!
SetTableCellRingItemAttribute(panel,
control,
MakePoint(column,row),
-1,
ATTR_BOLD,
TRUE);
The 4th parameter, index has invalid value
| index | int | The zero-based index specifying the ring item. |
So actually it's not a CVI bug
03-22-2017 11:27 AM
Thanks for your help! I was staring at this so long, I missed that index.
It's a shame that SetTableCellRingItemAttribute doesn't throw an error for out-of-index values. Oh well.
03-23-2017 02:20 AM
Yes, we'll keep around CAR #637529 with the purpose to throw a run-time error in case of invalid value of index parameter but it will have a lower priority
