LabWindows/CVI
German umlauts in project pathnames no longer supported in CVI 2013
Compiling files with German umlauts anywhere in the full pathname leads to the compiler error Build failed. No additional information. I'm looking forward to the next update..
(4,122 Views)
Accepted by ems174
Hi ems174,
We will be fixing this issue in the next update and you can track it with bug ID 422700.
Jonathan N.
(4,109 Views)
Fine, with the bug fix it is no longer necessary to change the directory and file names. Thanks a lot.
(4,098 Views)
