Get Serial port description With out Visa Intrument
Hi All
How can i get the description of a serial port ? eg. Communications Port (COM14)
I currently use the VISA Instrument but there is a big over head for the release, 65mb over head.
I would like to list all the available port for the user to select.
Shakeel
Help share your knowlegde
(4,260 Views)
Hi Shakeel,
I've found attached files years ago 😉
Have a look, may be a solution for your problem. After the detection you could use the RS232-functions.
WTD
(4,249 Views)
Thanks.
It helps in getting the com ports.
But my problem is get the description of that com port.
I got a USB which reads as a com port and the user wont know which com it is.
Is there a way via the registry or any other way to get the description of the com port?
(4,239 Views)
Accepted by Shako
You may find useful resources in this code published by Martin some time ago. Original code returns only the port number, but running it step-by-step you can find the point in which the text description of the device is found and use it.
(4,237 Views)
Thanks again.
That example does retreive the Name of the come port.
Best Regards
Shakeel
(4,234 Views)
