LabWindows/CVI
Get serial numbers of installed NidaqMx devices
Hello everybody,
i'd like to read out programmatically the serial numbers of the installed NI hardware. We're using PXI-1010 racks with SCXI-1127 muxes and PXI-4070 Dmm. Now i found the command "DAQmxGetSystemInfoAttribute" but this shows only the Muxes. Isn't there a way to find out all the hardware. The MAX can do it, doesn't it have an interface for CVI?
Thomas
(3,471 Views)
Hi Thomas,
From what I can tell, there is not yet a programmatic way to get the serial number for a DMM.  You can use DAQmxGetSystemInfoAttribute(DAQmx_Sys_DevNames, ...) to enumerate the DAQmx devices on your system, then use DAQmxGetDeviceAttribute(..., DAQmx_Dev_SerialNum, ...) to get the serial number for a particular device, but the 407x series of DMMs cannot be programmed with DAQmx (only with NI-DMM), so I do not believe they are enumerated by the DAQmx driver.
The NI-DMM API allows you to retrieve the instrument model (NIDMM_ATTR_INSTRUMENT_MODEL), manufacturer (_MANUFACTURER), and firmware revision (_FIRMWARE_REVISION), via the niDMM_GetAttributeViString function, but alas, no serial number.
This page talks about the NI-ModInst API, which does contain functions that allow you to query device information including serial numbers, but NI-ModInst currently only supports NI scopes (and ships with NI-SCOPE).
If the manufacturer and model won't do it for you, you can try looking at the registry keys installed under HKEY_LOCAL_MACHINE\SYSTEM, but that should be a last resort.
I hope this helps to clarify things.
Mert A.
(3,463 Views)
