LabWindows/CVI
Is it possible to select more than one item in the ring control???
hallo,
 Is it possible to select more than one item in the ring control???  by  using control button???
I have many items in the ring and i would like to set more than one item at a time...........using control button of keyboard...
Is thr any solution or must I use listbox with checkmarks????
I wait for your suggession???
thnq
raj
(3,254 Views)
I am afraid you will need to use a listbox and checkmarks: ring controls (the same as standard listboxes) accept only one active element at a time.
If you really need a multi-select list of elements, you could use the tree control: hiding connecting lines and plus/minus signs you obtain an aspect very similat to a listbox. The tree control also can hold different columns so that you can format your line content.
(3,247 Views)
Hi Roberto Bozzolo ,
Thank you verymuch. I will try to use trees as you suggested. But it would be really nice, if there is an option to select multi items in the ring by using control button  .....(just like in web applications)
regards,
raj
(3,228 Views)
