LabWindows/CVI
GetDiskSpace on real-time OS
Is there a way to query the free disk space in a PXI system running  the real-time OS.   I get lots of linker errors trying to use the GetDiskSpace function which works in Windows. (In Labview there is apparently something called Get Volume Info but I have not been able to find an analog in CVI 8.5)
Jim
(3,309 Views)
Accepted by kb3kj
Hey Jim -
The problem is that GetDiskSpace is implemented in the programmers toolbox, which isn't yet supported on Pharlap.  However, you should be able to pull the necessary pieces out of toolbox.c (<NI>\CVI85\toolslib\toolbox\toolbox.c).  All of the work for this function is actually done by the Win32 API function GetDiskFreeSpaceEx, which is supported on Pharlap.
Take a look at the source code, and let me know if you have any questions.
NickB
(3,304 Views)
Thanks NickB -  Using GetDiskFreeSpaceEx is working fine.
Jim
(3,280 Views)
