GetGraphCoordsFromPoint Bug?
GetGraphCoordsFromPoint does not seem to work right. It seems to have an offset and scaling issue in both directions. Has anyone else had this issue?
(4,201 Views)
Hi rmich,
Could you please explain what kind of offset and scaling you're experiencing?  The Help for the GetGraphCoordsFromPoint function state that "The pixel coordinates should be relative to the top, left corner of the panel. The return value indicates whether the point is within the graph plot area."
How does what you're experiencing differ from this?
Mark E.
(4,153 Views)
I created a simple app with a 100x100 graph and a callback to print the coordinates.
  case EVENT_LEFT_CLICK:
   GetRelativeMouseState (panel, control, &mx, &my, NULL, NULL, NULL);
   status = GetGraphCoordsFromPoint (panel, control, MakePoint(mx, my), &x, &y);
   if(status>0)
    printf("%d,%d = %lf, %lf\n", mx, my, x, y);
   break;
This is an example of what I get when I click on the graph:
Where I Click    Reported coodinates
0, 20                   4.3,28.9
30,70                 4.3, 97.3
100,0                 84.0, 26.8
100,75               84.0, 97.8
status is <0 for any Xless tha ~20 or Y greater than ~75. It will report valid coordinates by clicking below or to the right of the plot area down to the lower right of the graph control. It is as if the reported area is shifted to the right and down.
(4,128 Views)
Try calling GetRelativeMouseState() with 0 instead of a control value.
JR
(4,121 Views)
Accepted by rmich
Yes, that was it. I missed the subtlety that GetGraphCoordsFromPoint() works from panel coordinates, not control coordinates.
(4,114 Views)
