GetTableCellVal for Combo Box is returning float???
I'm using a Combo Box with a few strings as options.  When I use GetTableCellVal(panelHandle,TABLE_CONSTANT, Point that changed, &value) where value is declared as "char value[100]" I get the following error:
Invalid argument type: found 'pointer to array 100 of char', expected 'pointer to float'.
The documentation says the the GetTabelCellVal returns a string for Combo Boxes, not a float as with Numeric cells.  What am I missing here?  Thanks!
Note: The parameter "Point that changed" is pseudo code.  I form the Point type correctly.
Line from documentation:  If the cell type is VAL_CELL_STRING, VAL_CELL_RING, VAL_CELL_COMBO_BOX, or VAL_CELL_BUTTON, the function expects you to pass a buffer large enough to hold the corresponding string, plus the terminating NUL. Use GetTableCellValLength to obtain the length of the string.
(4,957 Views)
Hello Brandon,
For the last parameter you should pass value, not &value.
It's weird you get this message, for the same code I get the message:
Invalid argument type: found 'pointer to array 100 of char', expected 'pointer to char'. What LabWindows/CVI version are you using?
Constantin
(4,941 Views)
