LabWindows/CVI
Getting an "Unrecoverable error at 016F:867000F8" when I try to run debug mode
After Installation CVI 5.5.1,
I run "C:\MeasureStudio\CVI\Tutorial\sample5.prj".
When I am using Debug Sample5.exe, and press the "QUIT"
button on Sample5 program. There will be a message "Unrecoverable Error at
016F:867000F8...".
And I try to compile sample2, the same message showed while pressing "Quit" button.
If I run in Execute mode ( Execute xxx.exe Ctrl+F5)
This problem will not happen.
OS Ver : Win98 SE
IE Ver : 6.0.2600
Thank you very much.
(3,001 Views)
I tried running these projects on a similar system, and I did not receive these errors. Are you getting these errors on any projects that you run or just these? You may want to try reinstalling CVI incase something was corrupted in during the installation.
J.R. Allen
(3,001 Views)
Yes, I getting these errors on any projects that I run.
And I have reinstalled CVI
(1) Remove it from Add/Remove Control Box.
(2) Delete C:\MeasureStudio\...
(3) Delete C:\windows\system\CVIRTE CVIRTE.DLL CVIRT.DLL
(4) Reinstall it.
But the problem still going on.
If you need any information, I would provide you.
(3,001 Views)
