LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Graph Multi Y-Axis
Is there a way to add y-axis to a CVI Graph?
I want to have multi Y-axis on both the right and left side of a graph.
(3,958 Views)
Did you have a look at Roberto's contribution here ?
(3,955 Views)
I haven't but I will. Thanks for the reply
(3,952 Views)
I work with two left and right Y-axis. No problem.
SetCtrlAttribute( , , ATTR_ACTIVE_YAXIS, VAL_RIGHT_YAXIS);
SetCtrlAttribute( , , ATTR_YLABEL_VISIBLE, 1);
Now the right axis is visible
SetAxisScallingMode( , , VAL_RIGHT_YAXIS, VAL_MANUAL, 0.0, 1000.0);
But i don't known how i save a waveform in file and than read the file in chart.
Vaal
(3,933 Views)
This is a completely different question from the one that originated the thread: you should create a new question for it.
The easiest way to save a waveform (presumably an array of data) to file is probably ArrayToFile (). Similarly, you can read back the data with FileToArray (). Search in the help for the functions some explanation on their use.
(3,923 Views)
