LabWindows/CVI
HDF5 in Labwindows/CVI
Anyone succesfully implemented HDF5 in Labwindows?  I am have a lot of troubling linking to the libraries succesfully...any tricks?
(4,975 Views)
I have never used HDF5 except under LabVIEW, but there is an issue that effects both.  The HDF5 libraries, as distributed by the HDF5 group, use the C calling convention, not the winapi calling convention.
(4,968 Views)
Hi TorsionAxion,
The Help file has great information in Programmer Reference >> Compiler/Linker Issues.  Also, there are several examples in Communicating with External Applications >> Using External Code >> Integrating DLLs.
Cheers,
David Goldberg
Software R&D
(4,951 Views)
Dear all,
I am wondering if there are specific steps regarding compiling HDF5 library in LabWindows/CVI properly.
I have downloaded this HDF5 file from this link: "http://www.hdfgroup.org/HDF5/release/obtain5.html", I chose the file "HDF5188-win32-static.zip",
wondering if this is the correct file for LabWindows/CVI, or is it just for  CMake VS 2008 C, C++, IVF 11.1 compilers.
Best,
Matt
(4,405 Views)
I use 32-bit LabWindows/CVI. Visual Studio 2012 Express and Visual Studio 2015 Community are installed in my C drive. I have downloaded HDF5 pre-build binary distribution from https://support.hdfgroup.org/HDF5/release/obtain518.html. https://support.hdfgroup.org/ftp/HDF5/current18/bin/windows/hdf5-1.8.20-Std-win7_32-vs14.zip After executing the HDF5-1.8.20-win32.msi file, hdf5.lib , hdf5.h and hdf5.dll files are installed at C:\Program Files (x86)\HDF_Group\HDF5\1.8.20. I try to add hdf5.h and hdf5.dll file into my CVI project. During "Generate DLL Import Library" process, "sys\types.h" is not found. I can't complete the generation process. Any suggestion? I can find "sys\types.h" in VS2012 directory C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include. I can't find the similar path in VS2015. Any help?
(3,642 Views)
Hi leetehui,
Since this thread is several years old, I'd definitely recommend posting this in a new thread and referencing this current one so that way it can get more general visibility!
Applications Engineering
(3,631 Views)
