LabWindows/CVI
reading and sending mail POP3
Hello
I am trying to run the pop3client example.
what does the input needs to be in order to use my regular gmail account mail (an account that ends with @gmail.com) i tried pop.gmail.com
when i enter my user name does it need to end with @gmail.com or not.
In order to figure how to  Send Mail , the sendmail example doesn't work (it has no login input).
Best regards
Ido.
(2,251 Views)
Hey Ido,
I believe the username should be without @gmail.com. I would also double check that you have changed your Gmail settings to allow CVI to read your Gmail messages via POP. I've included a link below which outlines how to change these settings.
"Read Gmail messages on other email clients using POP": https://support.google.com/mail/answer/7104828?hl=en
Applications Engineering
(2,226 Views)
