Help: 1 project link error
error msg
underfined symbol_Word Rpt_ApplicationQuit @8 referenced in "name.c"
can anyone advice how to solve the above error ?
(6,039 Views)
Hi Chris,
Without any background information on the project, I would guess it might be an issue with target type.
http://digital.ni.com/public.nsf/allkb/BF8084DB74021EE986257AB200001737
- FCTesting
(6,026 Views)
Accepted by chris_chua
Is this the only error found  related to WordReport instrument? In order to use the instrument, you need to load it in the Instrument section of the IDE and possibly add the corresponding .fp to the project.
Do you receive this error in debug or release configuration?
Can you compile the sample project \samples\activex\word\wordrpt.cws without errors?
(6,020 Views)
hi
thanks for reply , i found the solution is i need to include all the driver file
(5,996 Views)
hi
thanks for the reply, yes  u are right it work now. but how to write a double data type to word file?
chris
(5,994 Views)
I've never used word report, but what about sprintf-ing the double into a string and write this one?
(5,980 Views)
ok thanks.. cheers
(5,977 Views)
