LabWindows/CVI
Help! About Spectrum Analyzer based on the sound card of PC.
I couldn't get the real thd value of 20Hz sine wave by my program,
How can I get a good 20Hz sine wave by the sound card?Adjust
its sampling rate?
The attached file is the parf of my program.
(3,872 Views)
you should use filter to denoise or replace a good sound card.
(3,849 Views)
Folks,
I see you made a application like mine in but C. Cool.
Still, I thought you may be able to help. I am a LabVIEW convert since 1995, but I suck at C.
Using LV2009 I made a decent do-it-myself sound card spectrum analyzer starting with a sound example vi.
Unfortunately it would not compile/build -- "Error 6" whatever that means.
(After all these years I just started using the app builder.)
Please help.
I want to share it with my EE buddies; here it is for you, too, attached.
--Peter
Also attached  is the crypto code from the builder/compiler.
(3,405 Views)
