LabWindows/CVI
script file
long Send_DAS3000_Command(char *sCommand)
    strcpy(sCmd,sCommand);
    strtok(sCommand,SCRIPT_SEPARATORS);
    strcpy(sFunction,strtok(NULL,SCRIPT_SEPARATORS));
    sprintf (sMsg,"SendDASCommand: sCommand = %s, sFunction = %s",sCommand,
             sFunction);
    DBGPRINT(sMsg);
    ERROR_LOG_FILE(sMsg);
    if (!strcmp(sFunction,SETFILE))
        //Sets the file location where the real time video capture
        //is going to be stored on disk
        if((iErrorFlag = Set_File(sCommand))< SUCCESS)
            const char *sErrorSettingFileName="Error setting FILE name.";
            ERRPRINT(sErrorSettingFileName);
            ERROR_LOG_FILE((char*)sErrorSettingFileName);
            MessagePopup("Error Message",sErrorSettingFileName);
            return FAILURE;
    else if(!strcmp(sFunction,FRAMES))
            strcpy (sSelectNumOfFrames,(strtok(NULL,SCRIPT_SEPARATORS)));
            iNumOfFramesSelected=atoi(sSelectNumOfFrames);
            //Configure the number of frames
            if((iErrorFlag = Configure_Frame_Grabs(iNumOfFramesSelected))<
                SUCCESS)
                const char *sErrorConfigFrames="Error setting frames.";
                ERRPRINT(sErrorConfigFrames);
                ERROR_LOG_FILE((char*)sErrorConfigFrames);
                MessagePopup("Error Message",sErrorConfigFrames);
                return FAILURE;
    else if(!strcmp(sFunction,CENTROID))
            iCurrentFrame.WidthCoordinate=atoi(g_sInstrData[FRAMEWIDTH]);
            iCurrentFrame.HeightCoordinate=atoi(g_sInstrData[FRAMEHEIGHT]);
            //Configure the frame count and capture the Centroid.
             //Within this function we are calculating x and y offsets
            if((iErrorFlag = Set_Param_Capture_Centroid(iNumOfFramesToSel,
                iCurrentFrame))< SUCCESS)
                const char *sErrorCaptCentroid="Error capturing  "
                                               "centroid.";
                ERRPRINT(sErrorCaptCentroid);
                ERROR_LOG_FILE((char*)sErrorCaptCentroid);
                MessagePopup("Error Message",sErrorCaptCentroid);
                return FAILURE;
    else if (!strcmp(sFunction,REL_MOV))
            strcpy (sValue1,(strtok(NULL,SCRIPT_SEPARATORS)));
            strcpy (sValue2,(strtok(NULL,SCRIPT_SEPARATORS)));
            dAZRelMovPosX=atof(sValue1);
            dELRelMovPosY=atof(sValue2);
            //MOving the gimbals by making a AZ and EL relative move
            //from current position
            if((iErrorFlag = Rel_Mov_From_Current_Pos(&dAZRelMovPosX,
                                                     &dELRelMovPosY))
                                                     < VI_SUCCESS)
                const char *sErrorRetrCurrentPos="Error retrieving\n\n"
                                                 "current position.";
                ERRPRINT(sErrorRetrCurrentPos);
                ERROR_LOG_FILE((char*)sErrorRetrCurrentPos);
                MessagePopup("Error Message",sErrorRetrCurrentPos);
                return FAILURE;
        //errorFlag equals VI_SUCCESS
    return iErrorFlag;
} //Send_DAS3000_Command
(4,591 Views)
//I need some assistance, basically I want to add more error handling in this section . basically in each strcmp function you will see, Im pulling from a script file.
//I want to be able to make error handling for  these particular section, the type of error handling i want to cover is if the commands coming from the particular file  is not on the line
//I want to handle that error at the moment,  Im going to post the text file, I know how to do it, but not  really using the strcmp really,
script file below
DAS, FILE,
DAS, FRAMES, 17
DAS, CENTROID
DAS, REL_MOV, 0.1, 0.2
(4,589 Views)
I cut out all my declaration, and the file is being open else where in the test set, so in this particular i didnt open the file here, so thats why you dont see, but the parameter sCommand
is pulling the commands from the script file, but i want to be able to make an error exception for each line that posted for the script file
(4,588 Views)
nevermind you guys i fix it, I made checks for what i wanted to do, i got a question is there a function to check whether im getting a digit value from the scritp file, like the 16
I want to make an exception for someone making a mistake and put anything besides an interger like DAS, FRAMES, ?7
? is not a value , so i want to throw an exception for that
DAS, FRAMES, 16
(4,585 Views)
1 meaningless subject, 4 posts in a row, no questions asked, no solutions provided...
That is a classic! 😉
S. Eren BALCI
IMESTEK
(4,564 Views)
lololololol
(4,561 Views)
besides i fix the solution already thanks
(4,559 Views)
