05-21-2015 02:58 AM
I done a simple software, it is full work ok on my windows xp pro.
However, if I copy it to other PC(same windows xp pro),
Histogram can not be display, but other feature is full ok.
See attachment image please.
I don't know why and I have search very many discuss in this forums but no any find.
Could you please help me ?Thank you very much.
05-21-2015 03:31 AM
1) What do you mean by copy? If you want to run your executable on a different computer it's better, i.e., more reliable, to create a distribution kit which is supposed to include all required files and settings.
2) Besides that it appears to me that the horizontal scales are different - maybe that's the reason why your plots look different: what determines the x-axis scale? Also your y-scale looks somewhat unexpected: histograms shouldn't be negative, in my opinion... The data sets you display are identical?
05-21-2015 07:25 AM - edited 05-21-2015 07:27 AM
When run my exe, if display "Don't found *.dll", then I will copy the *.dll to the computer.
Because my software is very small and simple, so I do not hope to create a distribution kit. It is too large and complicated.
Your are right, if run distribution kit ,then it is ok, no any error.
Yes, identical !
And , the software does not display any system error , fault or any other message.
Only Histogram is fault.
This is my code:
SetAxisRange(curveHandle, TABPANEL_2_GRAPH_Fe, VAL_MANUAL, min-1, max+1, VAL_AUTOSCALE, 0, max+1);
PlotXY(curveHandle, TABPANEL_2_GRAPH_Fe, axis, hist, intervals,
VAL_DOUBLE, VAL_INTEGER, VAL_VERTICAL_BAR, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
In fact, the software have not any error in my development PC.
So, I think it may lose some drive or other files for create Histogram. I guess.
05-21-2015 07:54 AM
So I guess this is the solution
I remember a post in this forum mentioning the files that are copied with a distribution kit, and the environmental variables set etc. but I can't find it now
, so all I can link is this general comment.
05-21-2015 08:15 AM
The forum post I was looking for is here
05-21-2015 08:49 AM
aha..Now I have solved it.![]()
Because I don't copy below 7 .dll files:
libguide40.dll
mkl_def.dll
mkl_lapack64.dll
mkl_p3.dll
mkl_p4.dll
mkl_p4p.dll
nianlys.dll
Foretime,if a software need access any .dll file but don't found it ,then it will display a message .
However in here, unexpectedly no any tips.....oh,,,my god...![]()
Thank you very much , Wolfgang, thanks again !
