LabWindows/CVI
How Do I enable multiple trigger voltages on the PCI-6221 using NI-DAQmx?
I am using the PCI-6221 to do some simple data acquisition.  The idea is to allow three different analog voltages to trigger the data acquisition state.  I currently have the code set up for one voltage trigger but I am not sure what needs to be done to add the two additional trigger voltages. Any ideas?
Thanks.
(3,238 Views)
Hi capncane,
The PCI-6221 does not have analog hardware triggering so what you will need to do is to acquire the triggers and your data signal continuously. Then setup a data manipulation, where you drop data points if the trigger conditions are not met. If the conditions are met, keep the data. I hope this helps.
Steven K.
Software Engineer
(3,210 Views)
Is it possible to do something as simple as this:
    DAQmxErrChk
        (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,0.0,5.0,DAQmx_Val_Volts,NULL));
    DAQmxErrChk
        (DAQmxCfgSampClkTiming(taskHandle,"OnboardClock",3000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,3000));
    DAQmxErrChk
        (DAQmxCfgAnlgEdgeStartTrig(taskHandle,"Dev1/ai0",DAQmx_Val_Rising,0.7));
or will I need to put the trigger on PFI0?
(3,188 Views)
Accepted by topic author capncane
Hi capncane,
The 6221 is not able to do analog triggering so DAQmxCfgAnlgEdgeStartTrig will not work for your card. Is your trigger a digital signal? If so what kind of level logic is it? If it is TTL you can use the PFI lines. If not you will need to trigger like I mentioned in my previous post.
Steven K.
Software Engineer
(3,173 Views)
