LabWindows/CVI
How to launch executable with arguments?
How to process this command line:
Test.exe -c foo > return.txt
(4,101 Views)
You find useful informations in this thread and the linked ones.
(4,087 Views)
Thanks a lot. That helps but, may I want too much :), redirecting standard output to file and then reading it back is not fast enough (about 10 msec on my PC). Is there any way to catch standard output faster?
(4,077 Views)
I have never tried to do this in windows, but you might try a style similar to the fork(), pipe(), dup() combination used in unix based cgi server programming. An example of what I am talking about can be found here.  And you should be able to access some Win 32 functions that do something similar.  Here is a reference. Let me know if it works out for you.
Jensen
(4,053 Views)
