LabWindows/CVI
How I fixed " Undefined symbol '___CompiledDebuggingLevel' ..."
For reasons too long to explain here, I often link a static library compiled with debug option to my main programs.
If I forget to switch to release mode library and I build the release configuration occurs a single linker error:
error: Undefined symbol '___CompiledDebuggingLevel' referenced in "c:\program files (x86)\national instruments\cvi2017\bin\msvc\cvistart.lib".
As far as I can understand, the debug mode library expects that someone defines the variable.
This issue should have be corrected in 2012 (CAR 372694) but it still occurs in LabWindows/CVI 2017.
With a simple additional source file, I have resolved the issue so I can safely forget 🙂 to manually switch the static library. If you have the same issue, cut & paste in a .c file and add it to your program sources.
// DebugLevelPatch.c
// A patch to really fix issue 372694
// By including this file in a LabWindows CVI project, you can avoid link errors
// that may occurr when you link a "release" executable with a static library that was
// built with "debug" options.
// The value of this variable is related to the "Debugging Level" setting in Build Options dialog box.
// We can know its values by printing it from a normal debug executable:
// No run-time checking = 1
// Standard		= 2
// Extended             = 3
// so the natural choice for a release mode executable is 1.
// If this could be included in "release mode" C startup code, it would fix the problem
// in a more elegant way.
#ifdef NDEBUG
int __CompiledDebuggingLevel = 1;
#endif
Carlo A.
Megaris
(3,736 Views)
Hi carlox,
thanks for your post! I'll go ahead and signal this to make sure it gets fixed, but in the mean time this is a great workaround.
Best,
CorraDIT
(3,702 Views)
