Color changing is not very intuitive in Excel ActiveX programming.
1) First you would get a range object of the effective range you wanted to change.
2) The using the GetProperty function to get a reference to the Interior property of the range.
3) Finally, us the SetProperty function to set the ColorIndex property of the Interior to a color index from the Excel color palette.
For example, something like:
error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
error = Excel_GetProperty (ExcelRangeHandle, &ErrorInfo,Excel_RangeInterior, CAVT_OBJHANDLE, &ExcelInteriorHandle);
error = Excel_SetProperty (ExcelInteriorHandle, &ErrorInfo, Excel_InteriorColorIndex, CAVT_VARIANT, CA_VariantLo
ng (5));
where, MyCellRangeV is a variant that contains a range string (i.e. "A1:B5") and 5 is the index of the color in Excel's color palette. 5 should be blue.
Remember to discard all of your object handles to Excel objects (ExcelWorksheetHandle, ExcelRangeHandle, ExcelInteriorHandle) so that Excel will shutdown properly.
Best Regards,
Chris Matthews
