In addition to the above resources, here is a link that talks about using inp and outp functions in CVI to communicate with parallel port devices
LINK. Another option is to use VISA commands. You should be able to set up your printer port and specify a resource name for your printer port in Measurement and Automation Explorer (MAX). Also, a tidbit of information that you may find when browsing through those parallel port resources is that I believe these ports are set up to have 8 output lines and only 5 input lines. These input lines however, are generally used as status lines, but you can still use those for norm
al input lines.
Jeremy L.
Jeremy L.
