LabWindows/CVI
How can I change the runtime engine to an older version?
How can I change the Run-time engine  to an older version?
After installing the Run-time engine 8.0 I want to get bach version 5.5.
When I deinstalled version 8.0 and tried to reinstall version 5.5 so it was not possible.
Also if I new installed the whole CVI-IDE, it was not possible to start any program, because there was not found cvirte.rsc.
Perhaps someone has a solution. Thanks.
Message 1 of 1
(2,972 Views)
