LabWindows/CVI
tab order and title bar visible
Hello all,
  I've been noticing for a while (in CVI 😎  that the title bar visible option keeps turning on for certain panels in the IDE.  I want the title bar to remain invisible for certain panels since I open them inside of another panel.  It wasn't until this morning that I finally realized that every time I change the tab order of controls on this certain panel that the IDE keeps turning the title bar visible again.  So if you change the tab order, go back and reset this checkbox manually...every time...again and again...ad nauseum.  The tab order has nothing to do with the title bar!  No other panel properties seem to be contaminated.  Can anyone else reproduce this?  Will there be a maintenance release to 8.0.1 to fix all of the new CVI 8 'features' anytime soon?
Orlan
(3,298 Views)
Can you post your UIR here with some instructions? I would like to try and replicate the problem on my system.
Bilal Durrani
NI
(3,284 Views)
Actually, I reproduced it here, sorry about this.
I'll forward this on to the developers for further investigation.
Bilal Durrani
NI
(3,277 Views)
Thanx Bilal.  Yeah, it's a behavior of the IDE.  It has nothing to do with the particular UIR file that you use (at least as far as I can tell).
Orlan
Message Edited by cosmo on 03-01-2006 10:16 AM
(3,274 Views)
