LabWindows/CVI
How can I customize the toolbar when using the attribute browser
hi Wolfgang,
You can close CVI to update the toolbars with the file.
You can suggest this feature to NI here: http://forums.ni.com/t5/ideas/v2/ideaexchangepage/blog-id/labviewideas
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
Message 11 of 15
(1,311 Views)
Hi Julien,
Thanks, I gave up too early, it wasn't clear to me that this dialogue box was not CVI...  So I managed to import the file but did not get the save file icon, despite the added line (item4): (I increased the item numbers of the subsequent entries accordingly)
<Key Key="Workspace Window Toolbar">
<Item Key="Workspace Window Toolbar\item1" Value="New Source File"/>
<Item Key="Workspace Window Toolbar\item2" Value="New User Interface File"/>
<Item Key="Workspace Window Toolbar\item3" Value="Open File"/>
<Item Key="Workspace Window Toolbar\item4" Value="Save File"/>
Message 12 of 15
(1,310 Views)
Yesterday I thought it was a good solution for your problem. Maybe you need to change more things in the file or understand better the file.
regards
Julien De Freitas
Message 13 of 15
(1,308 Views)
Accepted by Wolfgang
Wolfgang,
I hadn't realized that there were restrictions on which buttons can be added to which toolbars. Given this, and after some reconsideration, I've been persuaded that it is buggy behavior for the attribute browser (and the object browser) to be associated with the workspace toolbar instead of the UI Editor toolbar. This is being driven by an internal implementation detail that should not result in unintuitive behavior.
I've created a bug report for this: 382278
Sorry about this.
Luis
Message 14 of 15
(1,299 Views)
Thank you, Luis and Julien, for assistance!
Message 15 of 15
(1,294 Views)
