LabWindows/CVI
How can I make the property of data file Read Only?
This data file is received from my programm.I don't want someone could change it.
(2,945 Views)
You can use the SetFileAttrs() function (from the utility library) to set the read-only attribute of a file, eg:
result = SetFileAttrs("c:\\myfile.txt",1,-1,-1,-1);
Martin.
Martin
Certified CVI Developer
(2,945 Views)
