Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I make the property of data file Read Only?
Lab
Member
07-29-2004
03:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
This data file is received from my programm.I don't want someone could change it.
0
Kudos
Message
1
of 2
(2,944 Views)
Reply
Re: How can I make the property of data file Read Only?
msaxon
Active Participant
07-29-2004
05:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the SetFileAttrs() function (from the utility library) to set the read-only attribute of a file, eg:
result = SetFileAttrs("c:\\myfile.txt",1,-1,-1,-1);
Martin.
Martin
Certified CVI Developer
0
Kudos
Message
2
of 2
(2,944 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
