LabWindows/CVI
How can I seach a constant name or a label on the control panel?
Hi everyone,
There are so many controls on the panel, how can I  location one of them through their constant name or label?
thank you.
on the road to windows
liuerbin@hotmail.com
(3,669 Views)
To retrieve the constant name assigned to a control in the UIR editor you can use GetCtrlAttribute (..., ..., ATTR_CONSTANT_NAME, ...);
This can be integrated in a loop that iterates on all controls in a panel, this way:
    GetPanelAttribute (panelHandle, ATTR_PANEL_FIRST_CTRL, &next);
    while (next) {
        // Your code here
        // Verify wether there are more controls to scan
        GetCtrlAttribute (panelHandle, next, ATTR_NEXT_CTRL, &next);
The relevant question, nevertheless, is: are you *sure* you absolutely need to run this way? If you know which control you must locate and operate on, you can save this name in an array and use the array elements instead:
// Defining a global array of control IDs
int   ctrl[10];
// Saving relevan control IDs
ctrl[0] = PANEL_NUMERIC;
ctrl[1] = PANEL2_NUMERIC;
and so on...
// Using saved control IDs
SetCtrlVal (panelHancle, ctrl[0], value);
(3,664 Views)
Accepted by Robin Liu
I got.
  • Constant Prefix—Valid for panels and menu bars
  • Constant Name—Valid for controls, menus, and menu items
  • Prefix + Constant Name—Valid for all
  • Callback Function Name—Valid for all, except menu bars
  • Label—Valid for all, except menu bars
    (3,662 Views)
    sorry, the question is not described clearly.
    Using the Find command to locate an object in user interface resource (.uir
     , I fail to find the object because of misunderstanding the following choice:
    • Label—Valid for all, except menu bars.
    now it's ok.
    (3,658 Views)
