How can convert a string character that I have into a hex number?
I already saw some topics about this matter but this I could not convert the characters that I have to a hex number.
I have the following code, which has in the beginning an EEprom variable that has a string of 96 bits, and which and the gets split into 3 different Values of 32 Bit and then each one of these 32 bit values contains four characters.
I want to put these 4 characters
(shown in this Fmc funktion: Fmt(Result_Block0,"%s<%s%s%s%s",c_Char1,c_Char2,c_Char3,c_Char4); into a string that contains each hexvalue of these chars. But I could not find a way to do that.
I guess it might be not hard, I am just a beginner and still learning basic stuff everyday 🙂
I will be very thankful is someone can help me find a solution!
Thanks a lot in advance.
			//Ausgabe in Binär
			char EEPROM[100] ={0};
			Fmt(EEPROM,"%s<%s%s%s%s%s%s%s",b_sgtin_Header,b_Filter_ergebnis,b_Partition_ergebnis,b_Company_Prefix_ergebnis,vorangestellte_0,b_Item_Reference_ergebnis,b_Serial_Result);
			SetCtrlAttribute(sPanels.P_Hauptmenue, P_MAIN_EEPROM, ATTR_CTRL_VAL, EEPROM);
			char Byte_Block				[10]= {0};
			char B0						[40] = {0};
			char B1						[40] = {0};
			char B2						[40] = {0};
			 char c_Char1			[2] = {0};
			 char c_Char2			[2] = {0};
			 char c_Char3			[2] = {0};
			 char c_Char4			[2] = {0};
			char Result_Block0			[5]	= {0};
			char Result_Block1			[5] = {0};
			char Result_Block2			[5] = {0};
			char cRead_Block_0			[10] = {0};
			char cRead_Block_1			[10] = {0};
			char cRead_Block_2			[10] = {0};
			//Unterteilung der 96 Bits vom Data Matrix Inhalt in 3 Teilen. (Je 32 Bits)
			CopyBytes(B0, 0,EEPROM,0,32);
			CopyBytes(B1, 0,EEPROM,33,32);
			CopyBytes(B2, 0,EEPROM,64,32);
			//Unterteilung jede der 32 Bits in 4 * 8 Bits bzw. 4 Bytes und Umwandlung in ein ASCII Character
			//GTIN erste 32 Bits in Block 0
			Daten_EEPROM_Byte_VERTEILER(B0);
			DATEN_alle_Char_uerbergabe_Funktion (Byte_Block,c_Char1, c_Char2, c_Char3, c_Char4);
			Fmt(cCommand,"%s<%s%s%s%s",WRITE_BLOCK,"0_",Result_Block0,ENDE);
			//unsigned char str[100],strH[200];
		    int i,j;
		    unsigned char x_ResultBlock0[10];
		    memset(x_ResultBlock0,0,sizeof(x_ResultBlock0));
		    /*converting str character into Hex and adding into strH*/
		    for(i=0,j=0;i<strlen(Result_Block0);i++,j+=2)
		      sprintf((char*)x_ResultBlock0+j,"%02X",x_ResultBlock0[i]);
		    x_ResultBlock0[j]='\0'; /*adding NULL in the end*/
		SetCtrlAttribute(sPanels.P_Hauptmenue, P_MAIN_DM_SCAN_2, ATTR_CTRL_VAL, ("%x\n",x_ResultBlock0));
			// Write and Read Data in and from Block 0
			iResult = Befehl_Senden(cCommand,cAnswer);
			Fmt(cCommand,"%s<%s%s%s",READ_BLOCK,"0",ENDE);
			CopyBytes(cRead_Block_0,0,cAnswer,23,8);
			SetCtrlAttribute(sPanels.P_Hauptmenue, P_MAIN_DM_SCAN_7, ATTR_CTRL_VAL, cRead_Block_0);
(1,388 Views)
Hi, there is a bit of confusion in your post between bits and bytes!
You always speak of bits, but you are using bytes-oriented functions so it's difficult to understand the situation; just as an example, in the line
CopyBytes (B0, 0, EEPROM, 0, 32);
you say you want to split 96 a 96-bits block in chunks or 32 bits, but you are copying 32 bytes=256 bits!
You should either rethink your code or explain better the situation, possibly adding an example of what EEPROM may contain and what you are aiming to obtain.
(1,336 Views)
