LabWindows/CVI
How can i call FTP dos command in LabWindows CVI??
Hi Experts,
Actually i'm trying to transfer a file from a pc to another via LAN using ftp command in dos.
I tried to called ftp command from LabWindow CVI as follow:
system("ftp -n pcname < GetFile.txt");
where the content of GetFile.txt is as follow:
user ftp password
put filename.txt
bye
However, the file transfer is not successful....
I have tried out by typing each command line from the text file in the DOS command window and the file transfer is successful.
Can anyone tell me if i have missed out anything??
Thanks in advance...
(3,449 Views)
You need to use the -s option for ftp, i.e.
system("ftp -n -s:GetFile.txt pcname")
ftp -? for a list of options
HTH, HAND,
Martin.
Martin
Certified CVI Developer
(3,449 Views)
