Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I need an example of how to use the function MULTISELEC FILE
Cuco
Member
06-19-2003
03:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to select more than one file, and open these files, that is why I need an example cause I get some errors....
0
Kudos
Message
1
of 2
(2,925 Views)
Reply
Re: I need an example of how to use the function MULTISELEC FILE
msaxon
Active Participant
06-20-2003
07:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Assuming you mean MultiFileSelectPopup(), there is an example of its use in the on-line help.
We would be able to help you better if you describe how you are using it, and what errors you get.
HTH, HAND,
Martin.
Martin
Certified CVI Developer
0
Kudos
Message
2
of 2
(2,925 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
