LabWindows/CVI
I need an example of how to use the function MULTISELEC FILE
I want to select more than one file, and open these files, that is why I need an example cause I get some errors....
(2,927 Views)
Assuming you mean MultiFileSelectPopup(), there is an example of its use in the on-line help.
We would be able to help you better if you describe how you are using it, and what errors you get.
HTH, HAND,
Martin.
Martin
Certified CVI Developer
(2,927 Views)
