LabWindows/CVI
How can i compile my earlier CVI program with txengine.fp functions in CVI6.0?
I used txengine.fp function in my program, but i can not load txengine.fp in CVI6.0, how can i do?
(2,861 Views)
hello
What was the version of the earlier CVI program that you used this fp file in? What kind of errors did you recieve? How were you trying to load the fp file into the project? Is this a custom made fp panel or was this one that was provided with CVI? One of the main differences between the the fp's created with the older versions of CVI (5.0.x) was the limit in the function name lenghts. You might try changing by opening the fp file for editing, and going under Options >> FP File Format, and then selecting the newer format.
I hope this helps
Let me know if I missed anything.
Bilal Durrani
NI
Bilal Durrani
NI
(2,861 Views)
