LabWindows/CVI
Install other language messages in CVI 6.0 application
Hi. I modified file "msgrte.txt" to use my messages and that works fine (except font problem), but I have problem to include this file to distribution. Every time english version of this file is added to distribution and the file is installed after File Groups installation. It is not easy to change sequence in .msi and .cab files. Has anybody experiences with solving than problem?
Thank you.
Filip Kinovic
(2,837 Views)
Hi!
This method worked fine prior to LabWindows/CVI version 6.0, though changing msgrte.txt file was not really recommanded. The reason this method does not work well under version 6.0 is because now we use msi installers for creating destribution kits in CVI.
Any way, I can give you a workaround for version 6.0, but it would be better if I gave it to you directly rather than posting it here. Please go to
www.ni.com\ask
and create an email support request for CVI. In the problram description, please include that you have been comminicating with me.
Mika Fukuchi
Application Engineer
(2,837 Views)
