LabWindows/CVI
How can you insert delays between characters transmitted on COM1 to a routine generated with I/O Assistant?
The Sun TC01 temperature chamber I'm working with uses a 9600 Baud serial interface for control.  The example Basic code I've seen for the interface inserts delays
between each byte sent to the temperature chamber.  I tried using the I/O Assistant (without the delays) and cannot get commands that consist of more than one
character to work.  I'm concluding that a delay of 100 milliseconds or so is actually required between the characters.  So how can I customize the I/O Assistant
generated code to fix this problem?
(3,269 Views)
Sandia,
If you right click on the command you create in the I/O Assistant (Write, Read and Parse, etc) you can choose an option called Set Run Delay... This will allow you to set a delay after the write executes. You'd then just write one byte at a time with this delay.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(3,249 Views)
Thanks for the suggestions.  However, it seems like that command adds a delay *after* all the bytes are sent:
 // Format the number to be sent to the instrument
 ViErrChk(viPrintf(resourceName, "%-4.1fC\n", Centigrade));
 // Delay before executing the next step
 Delay(0.1);
Is there anything that could send the characters one at a time with 100ms delays between each character?
(3,244 Views)
If you want to send each byte with this delay, you would want to do something along the lines of putting the writes in a loop with this Delay function inside the loop and write one byte at a time. With this, you would no longer be using the I/O Assistant by itself, as you would need to change the text code that it is creating for you to function differently.
(3,238 Views)
