LabWindows/CVI
How do I AutoFilter a column in Excel in CVI
How do I filter a column in an Excel worksheet. I am aware that there is an activeX function Excel_RangeAutoFilter(). But I am not sure of the parameters to be passed to this function. Please help me.
Regards
Lakshmi
(3,837 Views)
Hi Lakshmi,
You can find more information about the Excel_RangeAutoFilter() ActiveX function on MSDN under Range.AutoFilter Method.  I think you will find all the information you were looking for there.
Jessica
Product Support Engineer
(3,802 Views)
Thanks for the reply. But now when I call the function Excel_RangeAutoFilter () I am getting error "No such interface supported'. I have pasted the copy of the code below. My aim is to autofilter column 2 of the workbook as nonblanks.
int Auto_Code_Excel_ResetAutoFilter(void)
     HRESULT errorCode      = 0;
     char errorBuffer[256]  = {0};
     unsigned int bufferSize= 256;
     VARIANT field;
     VARIANT criteria1;
     VARIANT criteria2;
     VARIANT visibleDropDown;
     VARIANT returnValue;
     int ret = 0;
     CA_VariantSetEmpty (&field);
     CA_VariantSetEmpty (&criteria1);
     CA_VariantSetEmpty (&criteria2);
     CA_VariantSetEmpty (&visibleDropDown);
     CA_VariantSetBool(&visibleDropDown,0);
     CA_VariantSetUInt (&field, 2);
     CA_VariantSetCString( &criteria1, "<>");
     CA_VariantSetCString( &criteria2, "<>");
     CA_VariantSetIntPtr(&returnValue,&ret);
     errorCode = Excel_RangeAutoFilter (workbookHandle,NULL, field,criteria1,ExcelConst_xlOr,criteria2,
                                       visibleDropDown, &returnValue);
     CA_GetAutomationErrorString (errorCode, errorBuffer, bufferSize);
     ExcelRpt_WorkbookSave(workbookHandle,"",ExRConst_DefaultFileFormat);
     return 0;
(3,705 Views)
Lakshmi,
You may have better luck posting this question in a discussion forum on MSDN as this function is officially supported by them.  Thanks!
Matt S
(3,670 Views)
