LabWindows/CVI
How to implement Matrox MIL imaging library under CVI
I am trying to implement imaging by Using Matrox CoronaII with Mil library. I am using LabWindows CVI 7.1 under WinXP. I am facing problems to implement this, especially transferring window handle to MIL. If anyone has an example how to do this, I will be very grateful.
(3,703 Views)
I have not used this library with CVI, but you can get the hWND of the CVI panel by using
GetPanelAttribute (panelHandle, ATTR_SYSTEM_WINDOW_HANDLE, hWND);
Hope this helps.
Bilal Durrani
NI
(3,695 Views)
hi,
  iam obtaining a matrix containing the image information from matlab in labview using a math script but functions like imshow do not work inside mathscript..so how do i use a compatible object to display the image
(3,502 Views)
Hey Barathindian,
Aashish M
CEO
TransferFi
www.transferfi.com
(3,459 Views)
