LabWindows/CVI
How do I connect to Notepad or WordPad using DDE in LabWindows/CVI?
I am developing an application in which I would like to allow the user to view a saved file prior to printing. I am running on an NT system without Office. While trying to connect using DDE, what is the correct server name for notepad or wordpad? Or, is there an easier, simpler solution?
(4,296 Views)
I'm not sure I get it right, but if you can display your saved file using Notepad or Wordpad, it must be only text? So why the need of a DDE connection?
The first thing that I think of is a Panel with a Textbox (Indicator mode) for the text and a Close button.
It would give you something like:
fopen(...);
while (fgets(..))
{InsertTextBoxLine(...)}
fclose(...);
Display (panel);
Is there a reason to use Notepad or Wordpad? If not, this should be much simpler.
Hope it helps, Flo.
(4,296 Views)
Thanks so much for you help! CMI
(4,296 Views)
