LabWindows/CVI
How to package a .ico file to my application?
Hi ,
I have taken note of that there is a API set which can display application icon in the system tray area .
But if I delete this ico file ,then the icon can not be displayed , so I'd like to know how to package such a ico file into my application ? So that anyone cannot destroy integrity of the application . Thanks.
David Lee
(3,482 Views)
You have to include it when you create a distribution kit. Go to add group and put all your image files in it and you can also specify where to install them after.
Let me know if I understand what you ment.
hope that helped...
(3,482 Views)
if you want it so that the ico file is hidden from the user, you can make a dll that would store the icon informaton in it. This would involve some win32 programming into your code, thats one way of keeping it packaged together
I found a useful document on using icon files.
Icons in Win32
you should also be able to find information on icon programming in the msdn at http://msdn.microsoft.com
Hope this helps
Bilal D.
NI
Bilal Durrani
NI
(3,482 Views)
