LabWindows/CVI
How do I freeze events?
Hello.
Is there a way to freeze the events coming from the user interface and then get them all together (for example with the ProcessSystemEvents function)?
Vasileios.
(4,989 Views)
Wrong approach.
The OS handles the event queue. Your application main thread processes these events. If for whatever reason your applicatin is running a computationally heavy chunk of code, user events m.ay not be processed promptly. Your interaction beomes slUgish. If that happens you may call the ProcesEvent type function or is you want to stop these events to bother your program, run your code it in a new thread.
(4,981 Views)
Hello vakost,
which behaviour are you intending to achieve with such a scenario?
(4,954 Views)
Hello.
I solved the problem with a different approach.
Thank you!
Vasileios.
(4,920 Views)
