LabWindows/CVI
Two clients connect to one server
Hi
I wrote program in LabWindows5.0.
I register my server and anything ok. When connect first client is ok.
when connect second client then first client is disconnect. Why?
Programs running on the one komputer.
My register function:
RegisterTCPServer (10000 /*port*/, CalClient, callbackData);
Sciana
(3,316 Views)
Are you using tcp/ip library? If yes, are you saving separate handles for
the 2 clients on server side?
vishi
"Sciana" wrote in message
news:e4eb55ce.0302070331.6b5c56a@posting.google.com...
> Hi
> Sciana
(3,316 Views)
I am facing the same problem have you solved ?
If yes kindly help me
Thanks and Regards
Umer
(2,935 Views)
