LabWindows/CVI
How do I get Graph value to an array?
I m new to this Forum.
I m making a data logger and the data's are plotted in a Graph.The graph would have 100thousand point and would have around 64 different plots.For offline analysis, I store the entire panel using SavePanelSate().This methode I use to store like a database.
And then once I recall the panel suing RecallPanelState(), I would like to Zoom, Scroll,Hide, Change the line type and Change the color of plots.
I can achive Zoom, Scroll but unable to Hide or change the color plot when the Graph is already plotted.
My question here is:
1) Can get the Graph plots to arrays ? so that I can replot..
2) If not then Is ther any way to change the plot colors or Hide, UnHide once plotted..
Hope I get some tricks here...
Thanx
Bala
(4,016 Views)
Hi Bala,
certainly you get some assistance here Smiley Wink
You also should have a look at the examples provided with CVI. For example, graphs.cws shows how to change the color of a plot...
In general, the function SetPlotAttribute (, , , ATTR_TRACE_COLOR, ); SetPlotAttribute (, , , ATTR_PLOT_STYLE, );, etc. will be useful for such purpose.
What is important is to have the 'Data mode' set to 'retain' and the 'Copy original plot data' checked.
(4,013 Views)
In case you want to retrieve plot data, you can use GetPlotAttribute function with the attributes
ATTR_PLOT_XDATA, ATTR_PLOT_XDATA_TYPE and ATTR_PLOT_XDATA_SIZE for the X axis and ATTR_PLOT_YDATA, ATTR_PLOT_YDATA_TYPE and ATTR_PLOT_YDATA_SIZE for the Y axis.
All Set/GetPlotAttribute functions neet for you to supply the plot handle, which you may need to store somewhere to retain the correct association between data/plots and actual trend recorded.
(4,003 Views)
