LabWindows/CVI
activex problem
I'm having a problem with activeX controller.
I build a exe wich uses an external activeX.
When I use this exe on the pc where the activeX controler was create, everything works.
If I use the same exe on another pc, it does't work even if a register the activeX dll in the new pc.
How can I make it work without having to recreate the activeX on the exe project to make it work?
(3,387 Views)
Hi Goncalo,
Are you creating an ActiveX server?  If so, there is a great resource for this located at the following URL: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fzikSAA&l=en-US .  This document also contains information on distributing your ActiveX application.
If you are not building a server, would you please tell me more about what your program does?
Thank you,
Daniel Dorroh
(3,369 Views)
